メインコンテンツにスキップ
2018年9月21日発売。モデル番号A1921, A2103, A2104、GSM もしくはCDMA / eSIM もしくはナノSIM /64, 256,もしくは512 GB/ シルバー、ゴールド、スペースグレイ(正しい発音は"iPhone 10 S Max")
375回答 すべてを表示
iPhone XS Max restarts every 4 minutes after screen replacement
I have an iPhone XS Max that appeared fine after a screen replacement. The screen is aftermarket, and the phone now restarts every 4 minutes. Everything seems to work fine in those 4 minutes, battery charged, cameras work, touch works, receives texts, makes calls. Is it just a bad screen? Already tried updating all of the apps and even restored the phone. I have the phone coming back in and will put the original back on to see if that fixes it. Any ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
7 件のコメント
update: phone came back in and original screen did not fix the problem. Have tried to restore again, and use TenorShare to fix any issues software wise. Still no luck.
さんによる
Any update on this issue?
さんによる
Still no updates or answers from anyone
さんによる
Welcome to the modern times of aftermarket screen replacements.
さんによる
Hey Matt,
I used to work for Apple and am assuming you did the screen replacement at a place that wasn't through Apple. You mentioned you already got the original screen back on which didn't help to fix the restarting issue. Is that phone still under the original 1 year warranty through apple? I assume that you didn't get Apple care otherwise you would have done the screen replacement through them?
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
The charging flex cable might have been damaged during screen replacement. Or you can also check the USB IC as mentioned in the repair guide here.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
change the frames 100% worked!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What do you mean change the frames
さんによる
コメントを追加
回答を追加する
matt mocciola さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 9
過去 30 日: 27
今までの合計 4,100
