メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
Screen Backlight on ONLY when lid is almost closed?
MacBook 2.16 GHz Intel Core 2 Duo Model A1181
When I first turn on my Black Macbook A1181 2.16 GHz Intel Core 2 Duo notebook, the screen's backlight will only come on when the lid is virtually closed. As the computer warms up, I can open the lid in smalls amounts. However if I open it too far, the backlight turns off.
This process usually take close to 45 minutes until I can set the lid at any position without the backlight turning off. Any suggestions? Difficult fix?
Should I replace the Inverter? Or could this simply be a cable issue? Is this possibly a MagSafe Board issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Apple MacBook "Core 2 Duo" 2.16 13" (White) Specs
Identifiers: Mid-2007 - MB062LL/A - MacBook2,1 - A1181 - 2139
さんによる
コメントを追加
5件の回答
ベストアンサー
Replace your inverter cable(s) and/or make sure the existing ones are properly seated. As you describe the problem, it is either in the cables or the connections.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
If you can still see the desktop dimly when it goes dark, this is your answer.
さんによる
Most definitely.
さんによる
This is an A1181 Macbook. It has a CCFL backlight. A CCFL backlight requires a certain amount of voltage for the inverter to to work properly. If it works at all, ever, consistently the problem is in the inverter cables or their connections 90+ % of the time.
さんによる
Sounds great guys, thanks a lot. If you have any idea if I should get the Display Data Cable over the Inverter Cable, please let me know!
さんによる
コメントを追加
Sounds like you have a damaged Display Data Cable. Here's how to replace it: MacBook Core 2 Duo Display Data Cable Replacement
If it is the inverter, here's the guide I wrote on replacing that: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
Here's the part you need:
MacBook Display Data Cable
Hook it up to an external monitor to insure that the problem is isolated to the display unit. If the external works, it confirms the problem is in the display unit. Holding a flashlight at an angle to the screen helps diagnose a bad inverter or inverter connection. You will be able to discern the desktop dimly.
A damaged display data cable can cause video defectsの画像
製品
$19.99
MacBook Core 2 Duo Installing LCD & Inverter (fast method) A1181の画像
ガイド
難易度:
中レベル
1 hour
MacBook Core 2 Duo Display Data Cableの画像
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks! This is great news. How would I know if it's the Display Data Cable, or the Inverter Cable?
さんによる
Good question, usually if you can discern the desktop when it's on it's the inverter or inverter cable. If you can't see the desktop then it's the display data cable. These things both get pinched in the hinge so the damage ends up being undetectable from the outside. The fact that it comes on when moving the screen is the giveaway on the cables.
さんによる
コメントを追加
Props to you guys for your huge effort and compendium of knowledge! I'll start with the cables and work from there!
You've been a huge help, the both of you!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The thing is, the back light is the issue... not the display. I can plainly see windows on the screen, even color and my background image changing. However, the back light is what is only coming on when it's almost closed.
As the computer "warms up", I can ever so slightly raise the computer screen. 45 minutes into this process, I can eventually open the lid all the way. But throughout this entire process, the back light will flicker, or turn off if I've opened it too much.
I would imagine the Inverter isn't to blame, since it's responsible for the actual image appearing on the screen--not the back light coming on.
Would I be safe to assume that it's a cable issue that would cause the back light to flicker, and only be on when almost closed?
Thanks for all your input. Promise this is the last question! Ha!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The fact that changing the screen position has an influence on the backlight screams it is a cable issue.
さんによる
I agree with AB completely. It's a cable. We just don't know which one, could be either or both, there's really no way to tell till you start replacing them. AB and I are not kids. We probably have 50 years of experience between the two of us. Trust us we don't make a dime for doing this, it's just public service. We don't work for iFixit. We repair this stuff for a living but here we just try to help people.
さんによる
コメントを追加
I have the same problem... could this be an issue with the lid switch? When the lid is almost closed the screen fully lights up... open it open and the screen goes dim again
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 7,091
