メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
PS4 not recognizing LAN cable
I was having issues with my WIFI connection so I switched to a LAN cable. My PS4 says to connect a lan cable when I am setting up network settings, but it is plugged into both the PS4 and router. The cable works on other devices but it is not recognized by my PS4.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
1件のコメント
I had this problem too but now it says that it cannot connect to the server within the time limit
さんによる
コメントを追加
13件の回答
最も参考になった回答
Hey this probably won’t help but I restarted everything including my ps4 blew any dust out of the ports Turn to connect to Wi-Fi off viewed connection status then went and set it up again and it worked
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I can connect my ps4 to my wifi but not my lan cable. The game is also constantly lagging.
さんによる
コメントを追加
Two things that came up to my mind:
  • Have you checked if there is no dust collected in the ethernet port?
  • Look under connection status and see what information your router is giving your PS4. You may have to re-enter it manually (even if it’s set to automatic).
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
I have checked, it runs on my laptop with no issues but when i go to change my PS4 from WIFI connection to a LAN connection, is where the problem is. I just get a screen telling me to connect a LAN cable when it’s plugged in
さんによる
Is there no dust inside the LAN port? Is it possible to test somewhere else? It’s not easy to replace the port as it’s directly soldered on the motherboard. What kind of issues do you have with the wifi ?
さんによる
My PS4 will download things in rest mode and stay on the dashboard with no problems but when I play games, is when it starts the issue. Every like 20-30 minutes, it will say WiFi connection lost, but as soon as I get that notification, I can rejoin a party because it’ll say I’m offline for about 3 seconds, no joke. I am able to rejoin a party before my party members see that I was left the party.
さんによる
Sorry for the late response! It could be a lot of things. Your Wi-Fi card or your antenna or maybe something software related. I had this issue too, keeps disconnecting from the internet two times. One time it was a bug in the game and the other time it was my router causing some trouble (firmware update helped). Do you have this issue with all your games??
さんによる
Any update my ps4 has bad speed on WiFi so I tried to connect to cable but ps4 not Recognizing it
さんによる
1以上のコメントを表示
コメントを追加
Please tell me you got an answer to this, it just happened to me today and I have no idea what is causing it
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
That is keeps disconnecting from Wifi ? Or does it not recognize the LAN cable?
さんによる
Hi, I am having this problem since 2018. So then I switched to WiFi, but my WiFi isn't very good. And now I want to use a LAN cable, but it keeps on saying LAN cable is not connected. I have tried switching my router, LAN cable, MTU settings but nothing helped. I also have tried rebuilding the database on PS4 but nothing helped. It's really annoying.
さんによる
I got same issue, now I'm waiting for my ps4 to came back from warranty service
let's see what they say about it.
It looks like it is a pretty common issue :S
さんによる
At the end I called PS service on last day of warranty and they replaced the main board
for me it looks like the ethernet chip is faulty
さんによる
コメントを追加
I’m having the same issue. I’m trying to use a Cat 5e cable bc that is what is running through the house. If there are any suggestions, tips, or fixes, please let me know.
thank you
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I am having the same issue can someone help.
さんによる
I found out exactly what the problem is. It is definitely not the PS4. It has something to do with your internet connection network settings. I was in my brother in laws house and no fix went home and connected to my internet with the Ethernet cable and boom it works.
さんによる
Any idea how to fix the internet connection?
さんによる
コメントを追加
Did you checked your cable? Is it working fine?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes, but no matter how many time I connect it just doesn’t work
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I keep getting a blue screen saying connect the DualShock controller and I keep doing it over and over and let it nothing happening
さんによる
コメントを追加
I need help fixing my internet on my ps4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same issue here. New cable. Tried multiple ports. Other playstation connects fine its just this one. Its never been able to connect via LAN.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not sure if anyone is having the issue still. I was with using an enternet cable. None of the above ways worked for me which I was screwing at! But I finally found out how to sort it! I updated the ps4 in safe mode. Turning the ps4 on and holding down the 7 seconds. Then choosing update system software, it rebooted and bang! It worked. No more working with 10mpbs. Back up to 125mpbs!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
what if the system says it’s already up to date, then what ?
さんによる
Good question
さんによる
コメントを追加
Possible Causes Why PS4 Lan Cable is Disconnected:
Different players experience different reasons, and that is why you need a diverse collection of methods to try to fix your PS4 Lan cable disconnection issue. The issue could be due to;
  • Updated PS4 Pro firmware
  • A faulty cable.
  • A flawed Ethernet port, etc.
Solutions to fix PS4 Lan cable not connected:
  1. Restart your router
  2. Insert LAN cable ‘halfway’ through to the port
  3. Modify DNS settings on PS4
  4. Establish static IP address for PS4
  5. Rebuilding database on your PS4
To lean more about how how to establish static IP and modify DNS check this article
https://www.geexshow.com/how-to-fix-ps4-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I’m trying to connect to my wireless internet but it’s switching on its own to lab cable and I don’t have lan cable I’m trying to go wireless which I have been doing for a couple of years
Can anyone help me
And asking for proxy server when I go wireless fyi
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is your LAN cable a cat7 or Cat8 Ethernet Crossover cable? I don't think a standard cable will work properly,
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am connect to the internet but can’t connect to the online serveres
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nik Mora さん、ありがとうございました!
統計データ:
過去 24時間: 21
過去 7 日: 127
過去 30 日: 643
今までの合計 86,586
