Why is my washer leaking from the bottom
My Cabrio model wtw8500dc0 is leaking water from the
bottom
Solution 1:
Tub-to-Pump Hose
The tub-to-pump-hose might be split or torn. If the tub-to-pump-hose is damaged, replace it. Do not attempt to cut off the damaged piece of hose and stretch the hose to fit the pump. Stretching the hose will put strain on the remainder of the hose and may cause the hose to suddenly rupture.
https://www.repairclinic.com/PartDetail/...
Solution 2:
Drain Hose
The drain hose may be leaking. The drain hose most commonly leaks from the connection between the pump and the back of the washer. If the washer is pushed too far against the wall, the hose can rub against the wall and form a leak. Inspect the drain hose for leaks. If the drain hose is leaking, replace it.
このアンサーは役に立ちましたか?
Sounds like the rubber seal behind the door has a hole or tear in it. I had the same issue and replaced mine and it fixed it. You can google your model for a parts breakdown.
このアンサーは役に立ちましたか?
My whirlpool was the same.
Pulled it out
Took of top(2 screws at back)
Plugged back in and on fill up I noticed dripping from soap add area. Build up of calcium had pushed apart the seal.
Unplugged
Took out unit 4x screws and undid clips
Scrubbed all calcified areas and rebuilt in reverse order.
No more leak 👍👍🤪
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 21
過去 30 日: 80
今までの合計 4,296
