メインコンテンツにスキップ
Repair guides and support for televisions manufactured by Sony.
748回答 すべてを表示
Sony Led TV - white line and cloudy screen - repair or not? Pic atchd.
Hi
My Sony LED TV 32inch. KLV 32EX33b showing white lines and whole screen becomes cloudy.
While I switch ON for few minutes the screen is clear, then vertical lines appear, and cloudy screen.
I called a TV mechanic , He said screen has gone and needs replacement.
First:
Second:
Third: Sometimes clear as this
Shall I go for new TV or repair or some DIY stuffs like cleaning the LVD cable ?
Looking forward for your suggestions?
Edit1:
Do I need to change the Board inthe image ? I tried cleaning the cable LVD but nothing changed.
Also How to find the below part number or name? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
The screen may not be the problem. It’s possible it’s the cables connecting the video board to the display itself. Was the t.v. dropped, knocked over or maybe hit by a power surge?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Hi, Thanks for your reply. TV was not dropped but there can be chances of power surge.
さんによる
Hi, can you please check the updated question and let me know your view. Thanks
さんによる
I searched sony KLV 32EX33b replacement video board and came up with the part. There's a video which came up in the results concerning double image that might help... if you speak Hindi.
https://www.youtube.com/watch?v=OO6P4vmH...
You could try that before ordering the part. I still do not think it's the screen. Since part search results change so frequently, I'm not linking those results.
さんによる
I replaced the boards on a smart TV a while back and the video was messy to say the least. When the boards were shipped, the cables were not connected. I unplugged the TV, removed the cables and turned them around. Switch ends connecting it. Try again.
さんによる
コメントを追加
i had the same problem and i found the solution here, https://www.youtube.com/watch?v=qEl1okrj...
you will see the CKT1, CKT2 track on the ribin cable just cut the 2 track very carefully without damaging any other track and it will fix your issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
logesh s さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 40
今までの合計 1,603
