メインコンテンツにスキップ
Repair guides and support for top and front loading Whirlpool brand washers.
425回答 すべてを表示
Washer stops early in spin cycle
I have a newer whirlpool washer and it worked fine for a while and now it is stopping early in the spin cycle leaving the clothes sopping wet . It is like it wont spin up all the way or as fast as its suppose to once it starts going so fast it stops and just starts draining no matter how many clothes or what size load it has ?
Update (10/07/2019)
It is a top loader btw..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
7 件のコメント:
Curtis Cole what exact model number is your washer? Explain this "once it starts going so fast it stops"
さんによる
Im not sure where can i find it it just says whirlpool on the front no numbers or letters
さんによる
Toploaders should have it somewhere on the rim under the lid. The issues you are describing sounds like a clutch issue. We need to know what model your washer is so we can check it out further.
さんによる
So the mod is WTW5000DW1
さんによる
I have this exact same problem with a Whirlpool Cabrio top-loader. Model # WTW7800XW2. Can you help?
さんによる
2件以上のコメントを表示
コメントを追加
1 件の回答
Its probably an issue with the computer in the washer. Call the manufacturer.
Update (10/07/2019)
When you pick up the lid, on the bottom left of it there is a screw. Sometimes if you tighten it, it will work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Curtis Cole さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 63
今までの合計 2,792
