メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dremel 4000は、回転数を可変できるロータリーツールです。すべてのDremel製ロータリーアクセサリーと互換性があります。
Dramel 4300 rotary tool 120v
I placed my tool into a 220v socket yet it takes in 120v and it stop working any help on how to replace the Electrical Assembly Replacement unit for the dramel 4300 Rotary tool and where i can find an Electrical Assembly Replacement for the Dramel Rotary Tool
i have used the picture for the Dramel 4000 becouse the admin seems not to have Dramel 4300 in the drop down
thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
You probably burned out the motor when you plugged it into a 240V outlet How did you manage to do that? normally the plugs are not compatible.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Could be in a foreign country that uses universal outlets? I am an American Vet living in the Philippines and I changed some of my outlets to accepts everything, I also have a commercial grade transformer for 100 and 120 while local voltage is 220. locally they do not have a third ground connector and also do not have the wide spade (polorized) connector as the USA does. Not sure how simple the dremel plug may be? I also believe that there could be 220 in the USA but the OP is saying 240 so I believe this is not in the USA.......
I recommend to open the tool, see if there is a possible fuse, if not, then replace the entire unit, by the time you get a replacement part, if available, and your time to change it, you will not save much money in the end.
さんによる
コメントを追加
回答を追加する
Brighton Albert さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 32
今までの合計 1,335
