メインコンテンツにスキップ
Repair information and support for GE Profile Refrigerators.
122回答 すべてを表示
Why is the water tube to the ice maker freezing
The water tube keeps freezing over and then popping out in the back of the ice maker. We have cleared the tube several times. Once it clears it makes ice for about two days and then freezes again. What can we do to keep it from freezing. The ice maker works well other than this issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Your water inlet valve at the back of the fridge on the bottom where the icemaker line is stuck open a little, maybe of hardwater deposits or sand ECT, needs to be replaced, it unplugs, 2 prongs and the hose going to the upper part of the fridge too all go together as 1 , it's not a part you can open it's sealed
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This is simple the water valve is not closing all the way . Has foreign stuff in it. Get a new water valve because it cant be taken apart .its located on the back bottom where the water line goes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
joebethhonea さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 40
過去 30 日: 177
今までの合計 2,859
