メインコンテンツにスキップ
Repair information for the Dell Inspiron 15 7560. This is a 15 inch laptop that is part of the Inspiron 7000 series.
2回答 すべてを表示
Potentially ominous problem discovered under hood of Inspiron 7570
I just removed the casing for a first time battery change after 18 months since I bought this device, and discovered that the foil on the hard drive is split, with a connector peeking out. In all other images/videos for this model, the foil is intact and no connector is visible. Can anyone explain what might have happened here? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You bought a machine that just came with an SSD and Dell included the cable and drive caddy so one can be added later. You didn’t get screws, but 2.5” drive screws aren’t hard to get.
Think of it like this: Your machine didn’t come with a drive, but it was provisioned so you can add one.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
You've really put my mind at rest. Thank you Nick.
さんによる
コメントを追加
回答を追加する
Steve さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 282
