How much to replace a ball joint, my right side is sideways
My front right side wheel is sideways
Replacing the entire control arm with ball joint included can be done by you and a friend in only a couple of hours, you can get all tools needed from your local parts store rental program. If you take on the job, use safety stands, you don’t need air tools but will take longer with hand tools such as a socket set, you will need wrenches also and a few other items as seen in the video.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 222
