メインコンテンツにスキップ
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
The brush rotates intermitantly, seems as if there is a loose wire
The suction is fine but, the roller brush rotates intermittently. It re-engages when I bounce the LiNX but not always when I turn it on and off. There seems to be a loose wire or connection somewhere. Any suggestions will be most welcome.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
I had a similar problem. However, my wire was severed. I had to open up the head unit and resolder it back together. Since that fix I have not had any issues.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Was the problem intermitent? Weems a severed wire would make it not work at all?
さんによる
Yes mine works intermittent too, not sure what is causing this.
さんによる
Same issue. I cleaned the brush but still doing it.
さんによる
コメントを追加
回答を追加する
Alan McDonald さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 617
