Can I replace or repair these cables?
can I repair these cables?
この質問は役に立ちましたか?
lucasmano96 I am certain you can. Since you did not tell us which wires and why you think you need to repair those, check the guides and see how the wires are attached to the inside of your headset
このアンサーは役に立ちましたか?
So the wiring through the head band got de attached. The one that runs through the headband and I’m not quite sure how to fix it.
Or if it’s fixable
@Bryce Bender detached how or where? Is it the same headset?
過去 24時間: 2
過去 7 日: 6
過去 30 日: 20
今までの合計 1,183
