メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
Is it possible to fix nand and cpu of iPhone 8 plus logic board?
this is a continuation to my previous questions. I damaged cpu and nand in iphone 8plus logic board while trying to replace back glass. Can cpu and nand be replaced or fixed, or do i buy a new motherboard? Thank you so much.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
They cannot be replaced, that’s for sure. As for fixing them, it depends on the extent of damage, but even the “simple” reball of the CPU is quite a demanding task. The NAND may also need programming tools and skills. In any case you probably need a reputable and very skillful microsoldering tech and some testing to be able to give a definite answer to your question.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I went on to put it dfu mode, now either it stays in recovery mode or stays on with apple logo.. nothing more. I dono how to fix it. what to do? is it good to buy a second hand motherboard? can you rely on second hand Logic boards
さんによる
@udaymaclean Symptoms point to a board failure, no idea if it could be fixed at all with the little info available. A used replacement board would be a viable alternative since the oldest in the market are just 2 years old, but in general their reliability is directly related to that of the seller, so choose wisely. Good luck with it.
さんによる
コメントを追加
回答を追加する
uday maclean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 760
