メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
260回答 すべてを表示
Vertical lines on the display?
Hello,
So I have a MacBook pro late 2016 15” laptop, which is almost unused. It was bought 25 months ago.
It didn’t get any external damage - but all of a sudden I got this annoying vertical lines on the right side of my display (and some horizontal ones on the bottom)
I really don’t get it, as nothing really happened other then me opening my laptop as usual.
Please advice!
Thank you very much,
Shy
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hello
If it was me I would connect it to an external monitor
From what your are saying it may be a fault display so I would be connecting an external monitor to it to see i it has the same issue or not
Let us know please
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sorry, didn't mention that I connected it to the tv - and it worked fine. So I assume the problem is with the hardware. I also ran a diagnostic and it came out as everything is fine.
さんによる
I leave it now up to the experts here on Macs to take it further There is quite a few so I am sure they will put you in the right direction
さんによる
コメントを追加
That's probably a bad display panel, or a bad connection between the display panel and the logic board.
If you don't have AppleCare for the repair to be covered or discounted, then you can take it apart and reseat the display cable. If that doesn't work, you'll likely need to replace the whole display.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shy Buba さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 153
