メインコンテンツにスキップ
The 2017 flagship cellphone for ZTE, model number Z982. It features a 6" display, USB-C, and runs on Android 7.1.1 Nougat.
22回答 すべてを表示
Why is my phone completely unresponsive?!
I was texting on my ZTE Blade Z Max, and it froze. Completely, volume and all. The touch screen won't work at all. (Mind you, it's not cracked at all.) And even when I plug it up to charge, it doesn't make a peep. Does vibrate, I don't even get notifications. And would ty and power it off, but my power buttons EXTREMELY tedious, not to mention I can't even see if the menu thingy would come up because it's frozen. I need help. FAST.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
If you can remove and re-insert the battery, that would be the 1st thing to try.  Next, see how to do a system reset.  That would be in the manual.  Usually, it’s pushing in two buttons at the same time for a period of time.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try to see if the screen pins are connected then try to fix it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Katie Sharp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 103
