メインコンテンツにスキップ
任天堂GameCubeコントローラーDOL−003。2001年11月に発売され、任天堂 GameCube、Nintendo Wii、Wii UとNintendo Switchと互換性があります。このデバイスの修理は簡単で、一般的なツールが必要です。
Left joystick is pulling to the right
My left stick pulls to the right, not consistent strength and not consistently all the time. I have tried a button reset (start, x, y) but that does not work. Any suggestions on how I can fix it w/out putting in a whole new stickbox?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@discardedcouch sound like a worn out analog joystick (weakened springs most commonly). Not much you can do but to consider replacing the joystick. This Nintendo GameCube Controller Joystick Replacement would get you where you would need to be to solder a new stuck in place.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Same things is happening to me, I bought a new TV and my Gamecube controller (an original one) started tilted to the right often when I pull left… it looks alright and centered on the controller but for example on Smash Ultimate menu or character selection, it often goes back to right when I want to go left… I managed to play online for an hour and then it happened again… I don’t think the TV or even the GC adapter is faulty cause my other Gamecube controllers are working fine for the moment. So it’s a spring problem ? Weird that if happened so suddenly, I mean two days ago it was fine… but I think I’m gonna try to open the controller to see.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Discarded Couch さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 22
今までの合計 4,622
