メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
220回答 すべてを表示
Is there a trick to replacing the battery cover screws?
Everytime I attempt to put the screw back into the battery cover,the screw seems to change polarity flip upside down or jump out and stick to the side of the case..
Is there a good tip /technique to doing this I wonder?
I’ve got this far after first time battery and display renewal,so this is infuriating to say the least !!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Magnetize a Screwdriver
the screws will then go to the screwdriver
One way and may explain the theory
https://www.wikihow.com/Magnetize-a-Scre...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks Bill
I was thinking that was why it was happening it seemed the screwdriver was changing the polarity hence the flipping over of the screw as soon as the magnetized driver and screw got near the hole -like it was being repelled like magnets do when you try and push them together if you known what I mean..
Never had that happen before so what was going on there I'm not sure...It shouldn't be spitting the screw out should it!
In the end I used an actual magnetic bar of the same diameter as the screw head and was able to start it off in the hole so it wouldn't be able to jump out and then screw it fully down with the driver...lucky to find that magnet , and now I'll keep it safe in my tools.
Thanks for the link I'll check that out
さんによる
コメントを追加
回答を追加する
EAMONN COLLEY さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 97
