Replaced belt now I have water coming out.
Serpentine belt shredded it self. I was able to replaced it myself. But now I have water coming out all over the ground. It wasn’t leaking before I replaced the belt. Any idea what it could be?
You need to prove where the water is coming from, it happens that when you replace a belt that the extra good tension is on the water pump, the bearing shaft seal will start to leak but make sure where the leak is coming from, fix that and your good, did you accidently put pressure on a hose and tear the hose a little?
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 3
今までの合計 42
Did you remove the water pump or loosen it while putting the new belt on?
mayer さんによる
