メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
iMac 21.5" EMC 2428 - Black Screen
Hi there
I have a 21.5” mid 2011 Imac, its the 2.8ghz i7 version EMC 2428.
The problem started a few weeks ago. I was away from the computer for 30 minutes and when I came back the screen was grey. I powered it down and on restart the screen remained Black. Checking online I found that the cure for this was a PRAM reset, I did this and sure enough the computer booted up as normal and all was good again.
It was fine for a couple of weeks, but it happened again. I powered down the computer and when restarting the black screen happened again. I powered down again and tried to start it up again with the PRAM reset, however this time the Keyboard isn’t being powered from the USB ports, so there’s no way of doing it.
I have tried an SMC reset and have also tried replacing the powersupply to no avail. The Imac seems to start up, hardrive starts up but there is no chime. I have shone a light on the screen, but cannot make out anything on the screen. The 1st and 2nd diagnostic lights are on inside.
Any ideas on what might be the culprit?
Cheers
Kieran
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sounds like a failed GPU. This is well know on the 2011 27” but not so much on the 21.5”
To confirm, hook it up to an external monitor.
Apple Radeon HD 6750M graphics card
Apple part # 661-5944 & 730-0629-A
iMac Intel 21.5インチ EMC 2428のGPUカードの交換
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you so much Mayer!
Changing the GPU worked and I have a working Imac again!
I’m eternally grateful my friend
Kieran
さんによる
@kizzer Glad it worked for you ;-) If this solved your problem, please accept my answer. Thanks
さんによる
コメントを追加
回答を追加する
Kieran Heighes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 319
