メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
299回答 すべてを表示
Ipad Not powering on after screen replacement
My iPad worked perfectly fine but the screen had a small hairline crack so I replaced the digitizer and when I tried to turn on the iPad after I finished it didn't boot up I checked to make sure all the cables are connected and the screws are I've tried connecting it to iTunes and nothing shows up. I think this is because I forgot to turn off the iPad before the repair also when the iPad is charging I can hear the motherboard making a high pitch noise it gets louder the higher the power of the USB is it is barely noticeable when the iPad is connected to a usb 2 port but it gets a bit louder when connected to a usb 3 port.
If anyone can help me that world be amazing
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Based on what you say, it appears the logic board was damaged. The iPad should boot up without an LCD and Digitizer so if it is not being recognized by iTunes, then the issue is most certainly on the logic board (check you cable and computer with another device just to be certain).
It’s very important to isolate the battery from the logic board when doing repairs. The typical issue is usually the backlight circuit but just about anything can go sideways.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
is there anyway to fix or anything? I have the same problem, i was fixing, then everything worked but then it just turned off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ahmed Abdul-Qader さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 258
