メインコンテンツにスキップ
The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
20回答 すべてを表示
cleaning of my tv
hey got a quick ???? my wife but a new micro fiber cloth to clean tv now there is smears all over it .....also since she used it it looks like back light bleeding..... on some areas could that just be the smudge marks cuz thats where they are …
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
jose rozy post some pictures of what your screen shows This "also since she used it it looks like back light bleeding" makes me a bit suspicious that there maybe more going on. iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
ベストアンサー
Here's how to clean a flat screen TV:
  1. Turn off the monitor. If the screen is dark it will be easier to see the dirty and oily areas.
  2. Use a dry, soft cloth -- the kind you would use to clean your eyeglasses -- and very gently wipe the screen. If this doesn't remove the oil or dirt, do not press down harder and try to remove the dirt. Pressing down on the screen will cause the pixels to burn out. Rather, proceed to the next step.
  3. Make a solution of equal parts water and vinegar (or water with a tiny amount of dish soap). Dampen a cloth in the solution and gently wipe the screen. Again, rubbing and scrubbing will damage the screen.
Here are some important tips you should know:
  • Avoid using paper towels, toilet paper or something like your shirt to wipe the screen, as these may scratch or damage the screen.
  • Do not use products that contain ammonia, ethyl alcohol, acetone or ethyl chloride. These chemicals, which are often found in commercial window cleaners, can cause the screen to turn yellow.
  • Never spray liquid directly on the screen as it can run inside the monitor and cause damage
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
jose rozy さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 11
今までの合計 140
