メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
This Asus laptop is a 2-in-1 touchscreen laptop. It can be identified by its model number: Q504UA-BHI5T13.
How do I fix or replace a hinge
This is the 2nd time my hinge has broken. First time I had Geek Squad fix it and they just sent it out to their main center instead of in store. This time I want to try to do it myself. The hing works but as I close the screen, the top cover separates from the LCD by the hinge. Do I need to replace the hinge? If so, how?
Update (09/16/2019)
It looks like this. I don’t even know how to get the display cover off. It almost looks like I can just attach the LCD display top better, it will work fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
it would be great if you could show an image
Is this the type of hinge you are speaking about
You need to replace the hinge. trying to repair it is a not the way to go
You should find one on ebay
Also a screw holding it in place may be missing
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rob Zeigen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 398
