メインコンテンツにスキップ
モデル番号 A1213/ 8, 16, 32 GB容量
216回答 すべてを表示
Danger from punctured or otherwise damaged battery?
Cheers,
today I opened my old iPod Touch to try to repair or bypass the home button.
While doing so, following the guide on this page, I damaged the hull of the battery. The guide suggested prying the battery off carefully with a spudge, which I did. Unfortunately the glue seemed to be quite strong, as some of silverish outer foil stuck to the glue and ripped the battery open. Underneath, within the battery some other, silver surface became visible. I noticed no smell, the iPod is still working.
I wrapped the battery in scotch tape immediately to prevent any moisture from getting inside. I'm unsure how to proceed though - I realize the battery is broken and should be replaced.
I also noticed however, that there were tiny punctures anyway on the label side of the battery, resulting from small pieces of dust which managed to get into the iPod and between the battery and the rear panel. So maybe it is not necessary for the outer envelope to be airtight?
Nevertheless I need to know: is there any imminent danger I should be aware of? Is it safe to store the battery in my home until I can dispose it properly or is there a risk of fire involved?
Thanks alot!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I damaged my iPod and decided that there was no point in having it because it was completely broken and bent. But then I saw a small print on the battery that said...
WARNING
Potential for fire or burning. Do not disassemble, puncture, crush, heat, or burn.
I became extremely nervous because I did crush the battery a little bit. I don’t know what to do or how to dispose of it.
Can I throw it away without burning my house down?
Thank you!
さんによる
コメントを追加
3件の回答
ベストアンサー
No risk of fire the metal is just shielding. Do dispose of the battery but your not in any danger.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have to jump in here. I punctured my iPhone 4 battery. The flare is so bright and smoke started to come out. It created fire. This was on side opposite to the little 4 pin connector. I tried to put out this little flare with my finger and it burned the tip of my finger so bad it melted the nail.
Now, this is no imagination and no movie. Please be very careful when you remove the battery. It does indeed catch fire if punctured badly.
I would put it in a closed non-metallic container and take it to proper battery disposal area.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes if u kept this battery in it home,the gas of the liquid will go to all it house and if lighted a match next to it,the gas will come right through ur lungs an u will die
このアンサーは役に立ちましたか?
スコア -1
6 件のコメント:
I am not sure what movies you are watching, but this is a pretty wrong answer....
さんによる
it's a wrong answer but a great imagination ;-)
さんによる
I thought about the same thing. I am sure I've seen it in a movie once :-)
さんによる
mcgyver? die hard?
さんによる
Now I remember, it was " The Third Man" starring Orson Welles, great film noir :-)
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Toastor さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 12
今までの合計 13,047
