dropped my j7 prime into water like a month ago
I dropped my j7 prime into water like a month ago and now it's just showing a j7 prime logo and it's not turning on help pleasee....... email:- 00akshasharma@gmail.com
@aksha the major issue you will run into is corrosion damage. The very first thing I would do is to disassemble it by following this video. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thoroughly with the sterile water. With the amount of corrosion that I envision, you will most certainly have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After all this you want to reassemble your phone and re-evaluate. Keep in mind that water damage is the hardest to troubleshoot and to repair. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 127
