メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
277回答 すべてを表示
MacBook Pro 13 turns off while loading after tea spill
Hey there! I accidentally spilled some tea to my Macbook Pro 13 (2017, Touchbar). There was a liquid near the On/Off button, the Touchbar and the upper right corner of the keyboard.
I immediately wiped the water off from the keyboard, and, as long as it was still working, I continued using it (I realised later that it was a big mistake). After 5 minutes of usage it turned off and now it turns off every time when I switch it on - it shows the Apple logo and turns off.
Can anybody suggest, what can be the problem?
P.S. I took it to the repair center in my country (Uzbekistan) the next day, but it has been a week since then and they still can't recognize the problem. They immediately disconnected the battery though…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
You’ve likely damaged/shorted the logic board, which will require professional microsoldering repair.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Repair specialists told me that water indicators on the logic board are white colored, which means that no water spilled to the board itself (otherwise they would turn red)
さんによる
コメントを追加
The logic board is extremely well protected from liquid entering via the keyboard. Certainly the uppercase has shorted out, but a replacement of it has a very high probability of fixing the problem.
UPDATE
Here’s how to replace the keyboard, in two parts:
https://www.youtube.com/watch?v=YMueATtT...
https://www.youtube.com/watch?v=Hg175WN2...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Should it be replaced? Are there any ways to fix it?
さんによる
コメントを追加
回答を追加する
Dan Ozzy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 16
今までの合計 104
