E91:01 is flashing on the screen
How to fix E91:01 flashing on the screen of the camera?
Try factory resetting the device:
main menu -> Settings -> Initialise -> Factory Reset.
Otherwise I believe that issue is with either the flash or the battery. You can try turning off the camera, removing the battery, leaving the battery out for a few minutes, and then putting it back in and turning it on.
Report back if that works for you :)
このアンサーは役に立ちましたか?
It didn't work for us.
過去 24時間: 0
過去 7 日: 8
過去 30 日: 20
今までの合計 1,092
1件のコメント
It didn't work for us. Tried chatting with sony. they said send it in for repair. Looks like it might cost $151. I'd love it if someone did a repair for the flash instructions. I think we'll use the camera without a flash.
Paul Lindblad さんによる
