carburetor for benchmark chainsaw
what carburetor is used on a benchmark chainsaw model BM38CVA
この質問は役に立ちましたか?
mack its actually a Poulan :-) MANUFACTURED BY: POULAN (ELECTROLUX) NASHVILLE, ARKANSAS U.S.A. SERIES OR ASSEMBLY NUMBER: 2300CVA
ENGINE DISPLACEMENT: 38 cc (2.3 cu. in.)
NUMBER OF CYLINDERS: 1
CYLINDER BORE: PISTON STROKE:
CYLINDER TYPE: Aluminum with chrome plated piston
INTAKE METHOD: Reed valve
CARBURETOR: Walbro WA series
mack should've told us that you already had that info. Poulan 2300 CVA and 2350 CVA chainsaws is equipped with Walbro Carburetor models WT 3 and WT 20
このアンサーは役に立ちましたか?
thanks I had all that info but I need to know what the WA number is WA ??
See if this helps:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 431
