メインコンテンツにスキップ
Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
Why is the canister loose?
The canister of my DC14 (with wheels) does not stay locked in. I have replaced the canister but it still is a problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
https://www.partswarehouse.com/Dyson-DC1...
Scroll down to the second exploded parts diagram
#4 Cyclone Release Catch
Maybe faulty -> worn, broken, not locking canister
さんによる
コメントを追加
2件の回答
It sounds weird but is there some debris blocking it from fitting properly? Have you placed the filter the right way around? I do not own one of these but i had this problem with a vacuum i have used. Hope it works!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a similar problem that I have resolved. My dustbin canister also seemed too low to align with the ports and the latch. I've since learned that there's a plastic piece on the top of the canister that has broken off. One option is to replace the canister top. I found another solution that seems to be working just fine. I inserted a shim between the hepa filter base and the bottom of the canister, about a quarter of an inch high. That seems to have solved the problem. If it's not satisfactory, I will buy a replacement top. Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Deb Kuron さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 18
今までの合計 1,181
