メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
Just did Battery replacement, but now flashing apple screen
Greetings all. Just did a battery install on my 7+ and now, when I try to start it up, it just flashes the apple logo…but won’t do anything if power isn’t plugged in. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
It appears you were right. Pluggin in the old battery, hard restart, and it's working again. I'm going to see about the other battery one more time, and then I guess request a replacement. More soon.
さんによる
Yep. Just replaced again, and it's back to it's old stuff. I'm going to let it charge for ten minutes and see if that doesn[t help. Otherwise, I guess I'll be carrying a rubber-band-held-together iphone for a few days until a replacement arrives. Thank you again so much!!
さんによる
You’re welcome. It sucks that it seems you got a bad battery, but with anything, there can be duds. Hopefully the new one works better :-)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Put the old battery back in and see if it does the same thing. It could be a bad battery. If it still loops with the old battery, it’s likely unrelated to the battery.
It could also be loop disease. The phone will run a self-diagnostic on startup and if it detects something not working (such as the audio IC) it can cause the phone to take a long time to start up or not start at all.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mark Lewis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 6
今までの合計 71
