メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015 Retina MacBook Airの修理情報とガイド。モデル番号はA1534
Random screen flicker 2015 MacBook
I was using my MacBook the other night when the screen started to flicker.
I tried the usual suggested resets, turning it off and on etc but nothing really budged, so I left it it a few hours and it was fine to use for a day or two until tonight when it started flickering again.
Dreading the bill to repair it!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Most of the time resetting the PRAM will solve this issue:
  1. Shut down your Mac.
  2. Locate the following keys on the keyboard: Command (⌘), Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Hold Down the keys
  4. While holding the keys, press the power button. Technically you don’t need to press them until it turns on, but you need to beat the gray screen, so it will be easier for you to just hold them down from the start. Keep holding.
  5. Hold the keys down until the computer restarts and you hear the startup sound (Chime) for the second time.
  6. Release the keys. Your mac is going to start up normally, and most likely the problem will be solved.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Unfortunately not, I’ve tried this and the SCM reset.
さんによる
When this starts are you going to things that may engage the graphics chip. like YouTube? It could be the switching from integrated to discrete graphics card or graphics card failure?
さんによる
Begins on startup, the Apple logo will have a vertical band through it.
さんによる
Try starting in Safe Mode by holding down the Shift key on startup to verify this is not a software problem.
さんによる
Still flickering in safe mode
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Joe Kerslake さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 501
