メインコンテンツにスキップ
The Hover-1 Coast (HY- SRMT) model number: CP2910, is an electric remote controlled youth skateboard that was released in 2018.
Why is my LiftBoard showing blinking red light when turned on?
I have a dual motor lift-board. I’ve had it for a while now but it’s been a since I’ve ridden it. It was good when I was using it. Now I’m trying to start using the board again and it won’t charge. The light keeps blinking red and I don’t know what to do. How do I fix this problem and if I can’t fix it can y’all fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Is there a pattern to the blinking? How long has it been plugged in?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Battery could have discharged too far. Recommendation is to get the wheels spinning for 10-15 minutes (they even go as far as saying to be pulled behind on bike) at roughly 10MPH. Check your remote to ensure it gets a little bit of a charge then try charging again.
I'm not sure what type of batteries these run but if they are LiPo, if not stored properly it can cause issues.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jay-U Kamara さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 2,481
