メインコンテンツにスキップ
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
88回答 すべてを表示
Where is the fuse for horn and drivers seat?
Horn is not working
Drivers seat won't lower down in the front. Also won't move up or down. The back adjusts. Lumbar works and back part of seat will lower.
When I try the front and up and down it clicks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
novatay1 those things are not related by a fuse. the horn fuse is in the fuse box under the hood besides the battery. Fuse #18 is the horn fuse. You also want to check the horn relay and the horns. With all the adjustments you can do on your seat is is not a fuse that is a fault here. you said that “When I try the front and up and down it clicks “ so I would check the motor for the seat. The clicking is most likely the relay. You need a multimeter to test this. Here are the chapters that will help you with the diagnostics and repair Power SeatsHorn
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
novatay1 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 33
今までの合計 676
