メインコンテンツにスキップ
Repair guides and support for your Philips TV.
243回答 すべてを表示
I have no picture (black screen). Sound and Ambilight still works.
My Philips 55PUS7101/12 is exactly 3 years old and the screen just stopped working.
I still get sound and light from the Ambilight.
Can I order any part and solve this by myself?
Update with pics from Multimeter 10/9/2019
Goes from 65.5 to almost 0
Power is on
Update 14/9/2019 (CN9101)
Update 3/10/2019
3 images of Main Board
1 image of the power to LED/Ambiligt
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
19 件のコメント
Hey,
did you solve your issue?
さんによる
HI, I have the same problem: black screen but backlight is OK
Marcus, you found something ?
THANK’S
さんによる
hello guys, i had the same problem, tv was working but i had a black screen (not even the philips logo shown at startup). my problem was one of the flat cables, somehow it wasn't in the right position.
The two cables were missing small parts from the sides so it didn't fit perfectly. This means that the cable didn;t slide perfectly into position and the very small pins i think weren't toching the right pins from the cable.
After like 5 tries of adjusting the cable, started at the maximum height, and slowly moving the position of the cable lower, i found the right position and my problem was fixed. Of course you have to disconnect and adjust the cable with the TV off and.
I hope this information help you figure it out if it is the same problems.
さんによる
Hi, my name is Laurent. I am facing the same issue as discribed (no display at all) but audio and ambilight working. Did someone found the solution for this problem ? I already changed the SSB board, but still no VIDEO at all. Thanks in advance for your help.
さんによる
Hi Laurent! Did you try to shine a strong flashligt on your screen while the tv is on? I have sound and ambilight, but no picture, but when i used a flashlight and looked at the panel i saw picture. As far as i know the background light is controlled by the TCON card.. i found a fuse on my card that didnt look good.
さんによる
14件以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
Marcus Sätherström  when you turn your TV on and you have sound indicating that you are on a valid channel, shine a flashlight beam at an angle against the screen . See if you can make out shapes etc. If so it is your backlight that may have failed. If not then it is time to remove the back from your TV and take a look at the boards. This can be a power board as well as a main board issue. Take some good pictures and post those with your question, that way we can see what you see . Also, on your T-con board is a fuse. With your TV on, check the fuse to see if there is power on it (12VDC). Try not to shorten out any pins while checking on a live TV :-)
iFixitでの質問に画像を追加する方法
UPDATE 09/08/2019
Marcus Sätherström the fuse is the one with the red arrow on it. Use your meter in ohm mode and place one probe on either side of the fuse (blue arrows) and watch your meter. If you have continuity it will move the needle (analog) or move from a high value to 0 (depends on your meter). If you have continuity, check for power (yellow arrows). With the TV on place the red probe on one of the points on the fuse and the black probe to ground with your meter in VDC mode. You should have around 12V on it.
Update (10/08/2019)
Marcus Sätherström  page 46 would be of interest. See if you can use it to narrow it down further Philips-QM16.3E_LA_part-1.pdfPhilips-QM16.3E_LA_part-3.pdfPhilips-QM16.3E_LA_part-2.pdf
このアンサーは役に立ちましたか?
スコア 3
34 件のコメント:
Thanks for your quick reply! :-)
I don’t get any shape when i use a light to see on the screen. I will open up the TV and post some pictures and hopefully you can help me out with this! :-)
I don’t know what the T-con board is. Maybe you can help me out with this as well :-)
さんによる
@oldturkey03 Pictures are live and ready! :)
さんによる
Marcus Sätherström  the last board you found is your T-con board. If you remove the plastic cover you should find the marking “F1” on that board. That will be your fuse. I hope you have a multimeter available to you for testing purposes.
さんによる
@oldturkey03 Ok, I have posted a new photo of the board. I can't find de "F1" you are talking about.. Do you see it? Yes I will soon have a multimeter for the testing.
さんによる
Marcus Sätherström yours is right above the power connector. That is the one with the red and black wires. Let us know when you have a multimeter.
さんによる
29件以上のコメントを表示
コメントを追加
Hi!
Try to disconnect the 51 pin ribbon cable from the T-con board!
If you have than color screen looping(white, red, blue, green), than there is a problem with that cable!
I‘ve got the same problem, and I solve it with an eraser.
I put it on the connection by the T-con Board, and screw back the metal plate!
It pushes the connector down, and the picture is back!
This is a permanent fix, I don’t know how long it will be, but it cost‘s you „nothing“!
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Where is that 51pin conector?
さんによる
Hi
I am so non tech so please be patient.
My TV model 49PUS6561/12
has sound and ambi light but black screen. I have read the other comments but really don’t understand what I can do to try to fix this.
Can any one help please. I think I have had this TV maybe 4 yrs
さんによる
コメントを追加
For us it seems to be the logic board, the one with the HDMI connectors. The power board feeds the logic board and the logic board provides the power to the middle board what should feed the backlight. 2/3 boards replaced now.
All 3 boards replaced. No go:( a well, worth the shot
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Change the backlight strips you can test it with a flashlight point it at the screen if the tv is on
さんによる
コメントを追加
I'm just reading this with my TV opened up, the logic board is getting power fine. I think this might be a software problem and it needs a hard reset but on my model (philips 55pus6703/12) this is not possible.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi @cbdb22714,
You should be able to do a hard reset (power refresh) as all this is, is disconnecting the power to the TV and then pressing and holding the joystick key on the back of the TV for 30 seconds, then releasing it and reconnecting the power and then using the remote or the joystick key to turn it on. This should drain any residual power from the TV and reset the firmware
See p.9 of the user manual for the location of the joystick key.
さんによる
Doesn’t work, I have been trying and still black screen. I can connect my phone with the tv and play music but no pictures, I tried to use the Philips control app, but to connect it they send a code to the tv, so I can’t see it
さんによる
コメントを追加
回答を追加する
Marcus Sätherström さん、ありがとうございました!
統計データ:
過去 24時間: 23
過去 7 日: 190
過去 30 日: 753
今までの合計 43,380
