Can you reconnect the fine electrical wires if they have snapped?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Should be able to as long as the wire is viable on both sides of the break. Solder and heat shrink wrap should do the trick.
このアンサーは役に立ちましたか?
As long as the wires are visible, you can resolder them. Just make sure to put some heatshrink tubing on before!
Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 109
