clincking on and off
turn tv on cut back off
Clyde Haynes not a lot of description here :-) . For now I suggest that you might want to consider checking the no power flow chart. Your issue appears to be related to the power failure circuit. You will need a multimeter to check those components.
you also want to check on the power failure circuit
Let us know what you find. Another thing that can be helpful to find an answer is you adding some good pictures of all of your boards with your question. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 34
1件のコメント
https://www.ifixit.com/Answers/Device/Sa...
prop man さんによる
