メインコンテンツにスキップ
Curved screen LED monitor released by Samsung in May 2015, identifiable by the model number S27E510C.
4回答 すべてを表示
Blackness on part of screen and cracks
This morning my Samsung 32in curbed monitor fell and cracked under the screen (no outside damage) and that side of the screen is black. Is there a way to fix this without paying bcuz it could just be a technical issue even though I fought that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
yup, these are super easy to break. i broke 2 of these monitors. i have traveled with other monitors all over the world but these are soooo breakable. So far i have just bought new ones to replace the broken ones.. tigerdirect has refurbished ones for $149
さんによる
コメントを追加
2件の回答
You likely cracked the lcd (liquid crystal display). Unfortunately once the liquid is out, there's no easy fix and you'll have to replace the display.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Brownbailey may be correct. Computer monitors are considered to be Field Replaceable Units, which means that they only get replaced by technicians, not repaired. Opening some types of monitor without the right equipment may even be dangerous because they can still hold a charge even if turned off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MyMonitorBroke さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 33
今までの合計 760
