メインコンテンツにスキップ
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
302回答 すべてを表示
Truck won't start after driving
I can start the truck and drive for several hours . Get home turn it off let sit for several hours try to start it but just continue to turn over but won't start. I don't think fuel is dumping from the injectors but I can hear the fuel pump
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hey, Daryl. The first thing I suggest is checking for spark. You can obtain an inexpensive tester at an auto parts store, or make your own with an old spark plug. Once you can say whether or not the spark plugs are firing I would check for fuel. Get a can of starter fluid from the parts store, remove the air cleaner assembly and spray a little bit into the throttle body. If it starts up and runs for a moment before dying, you likely have a fuel issue. Let me know how these first tests go and I’ll guide you from there. Good luck with your repairs!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Daryl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 8
今までの合計 57
