usb dissconnect high power device
SONY BRAVIA KD55EX7073SU
Keeps showing High power device please disconnect USB showing bottom right even with nothing at all connected at all
weird, in case you haven’t disconnect the power and press the power button on the right back (if it’s like mine) to make sure it’s drained and plug back in. you could also try cleaning the USB port with something wood or plastic such as a tooth pick, and also update the firmware which can be done via wifi I think around the device info or support section in the settings.
このアンサーは役に立ちましたか?
Tried all that no change tv still the same thanks
Wait for some several minutes then press home button or ok button to solve it ……thanks me later ?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 8,833
Sony LED TV high power device please disconnect
Vishnu さんによる
Sony LED TV high power device please disconnect USB
Vishnu さんによる
My Sony Led modal no KLV28R412B IS PROBLEM SCREEN SO HIGH POWER DEVICE PLEASE DISCONNECT USB
SUNIL KUMAR さんによる
Sony Bravia showing high power device please disconnect usb but no usb connected
Vinay Dongre さんによる
I have just bought led strip lights for my Sony bravia TV. TV keeps saying
High powered device. Please disconnect USB.
Is there any way to stop this pop up on screen as its to big and distracting.
Peter Spanner さんによる
2件以上のコメントを表示
