メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Craftsman 315.108220 is a corded 7-1/4" circular saw with 2-1/8 HP.
How to lock the blade shaft on a Craftsman 315.108220 circular saw?
Does anyone know whether there is a “brake” on the driven saw blade shaft of this model so you can unscrew the blade bolt? If not can you suggest how I can lock the shaft and remove the blade bolt? The blade is loose and freely rotates on the shaft but it is impossible to remove the blade bolt because the blade shaft and the armature turn. I seek suggestions how I can lock the shaft and thus remove the blade bolt. Because the saw blade can not be removed, I can’t fully disassemble the saw and thus gain access to the gear case where I could lock the shaft..
denniswaller@comcast.net
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
From the owners manual (https://c.searspartsdirect.com/mmh/lis_p...) the answer is “no”. Set the saw on a bench or other suitable support and use the attached blade wrench to loosen the spindle nut, holding the saw down with the guard UP so the blade is captured by the bench-top and kept from moving. Alternatively, on tight blades, I’ve always inserted a screwdriver shaft between blade teeth to “jam” the blade from moving. In a pinch you can also grip the blade with some pliers or channel-locks.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
The blade spins Freely , how to grip the entire motor period...only way to remove bolt is by holding the entire spinning mechanisim.....now what ?
さんによる
The washer between the bolt and the blade is keyed. You can get some channel lock or pipe pliers in there, grip that washer securely, then loosen the nut while gripping that washer securely. That will allow you to loosen the bolt. Once It's loosened you should have no problem changing your blade.
さんによる
Does seem like crap design oversight. When you can easily find a blade lock on so many saws today, why wouldn't they just include one? Fartin' Craftsman....
さんによる
コメントを追加
回答を追加する
Dennis Waller さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 22
過去 30 日: 59
今までの合計 7,187
