While powering on the laptop enters the lenovo diagnostics. Why?
Please answer the qustion friends
If it keeps going to diagnostics screen it sounds like it can not find a bootable device. Most likely either the hard drive has gone faulty or windows needs to be re-installed on the hard drive.
このアンサーは役に立ちましたか?
problem solved...👍👍👍👍👍
To launch the diagnostics, press F10 during the boot sequence launch Lenovo diagnostics. Additionally, press F12 during the boot sequence to access the Boot Menu. Then press Tab to select Application Menu and arrow down to Lenovo Diagnostics and select it by pressing Enter.
This May Help,
Peter
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 25
過去 30 日: 129
今までの合計 5,053
2 件のコメント
Hi Vivky !
Can you tell us more about it, please? Following which event is it in this mode? Has the restoration been completed? Thank you for the clarification.
Schwarzer さんによる
Hi schwarzer,
If power on laptop Entering lenovo diagnostics Screen nothing can do it.
Vicky Jayabal さんによる
