メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
First audio ic attempt goes bad...!
Yes, I’m totally inexperieced and yes, I never did anything similiar. Total noob..
Some are ground and some not connected but there are missing also connected pads, like A9, A10, A11, B11 etc.. Is this even recoverable ? I saw a video when the guy scratched off the glue and made some jumpers for recreating the pads, .but this seems just so desperate, there are so many.
SHould I give up, and just sell it for parts? Let me know and thanks ..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Do yourself a favour and just forget it, take it as a mistake and write it off. Trying to fix that will only lead to further frustration and time wasting. If you don’t keep it for parts, please be clear with your buyer about the board condition. Just my 2c.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
Ok thanks .. i read about this issue , and it seems caused by pulling the chip while pads are not totally melted.. is this correct?.. maybe it needed more heat or time
さんによる
@denv You're right, a combination of low temperature and pull force. Pads are very thin, little more than a hair and although they're virtually part of the board they are very fragile. I'd suggest touching the IC sideways a little bit to make sure solder is fully melted before lifting the IC. But it's just a personal approach, each of us develops his/her own feel for it, practice is very important.
さんによる
Do I have to pratice with iPhone ICs or I can try also with other phones? I have older models like 2000s Motorola, or more recents like Nokia Lumia.. and also a little advice with temperature and time? I know everyone uses different, but I'm curious....
さんによる
@denv Ambient and board temperatures can make a difference, as well as the size of nozzle used and Pcb holder. Personally with BGA on iPhones I prefer to work around 350C. when dealing with lead free solder and around 320C. with leaded. A thermocouple might help you verifying temperatures. Some work with lower, others with higher temperatures though. I don't like using a preheater, others seem to love it. As for practice boards, anything will do to start with, but when you get some feel and confidence I would recommend to shift to the boards you are inclined to work on.
さんによる
コメントを追加
I’m a first timer with micro soldering too, but I think you pulled out many many pads. I was watching YouTube videos and they say pulling pads is a huge no no. You gotta rewire each pulled pad, to where the chip was taking it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes..definitely not worth, too many hours on it to solve.. You have some advices for the next time? I'm a little discouraged now , but I'm going to pratice
さんによる
コメントを追加
回答を追加する
Denv さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 343
