メインコンテンツにスキップ
The Microsoft Lumia 540 is a low-cost smartphone identified by model number RM 1141.
5回答 すべてを表示
How can I Recover data without PC?
Hello.
So I have a Microsoft phone (model: RM-1090)
And there is an issue. I need to recover files and images because they were deleted after a hard reset. Problem is, that I cannot charge this device with an ordinary charger because the usb (on the device) is not functioning. So everytime I want to charge the device I have to manually remove the battery and charge it, in an external charger.
The usb not functioning means that I cannot connect my phone to a pc so I can recover the data.
Is there any way, to do the recovery procedure inside the phone without using pc?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi ,
Since the phone is working have you thought about using Bluetooth to transfer content etc to a paired BT device?
Here's a link that may help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
GO4GAME さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 5
今までの合計 122
