メインコンテンツにスキップ
フォルクスワーゲンによる車両用の修理ガイドならびにサポートです。
514回答 すべてを表示
Volkswagen 2012 Tiguan water and black particles coming out of exhaust
I recently bought a 2012 Volkswagen Tiguan.
I have many problems with it:
1. Engine idles kinda rough
2. Engine usually spits out a good bit of carbon particles and water once the engine gets up to temperature.
3. There is some hesitation on moving off and the engine tends to stutter while idling or slowing down.
4. Took it to a mechanic, did a diagnostic and said that the following error came up: Oxygen Sensor bank 1 sensor 1
He also noticed some oil leaking from the upper engine cover gasket seals. He said to replace 06H 103 483C and 06H 103 483D.
I would like to know if replacing these seals and the sensors would stop the rough idling and the carbon dust coming out the back?
And should i go through with the hassle of replacing the seals or just get rid of the vehicle. I would be grateful for any advice!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Replacing the valve cover gaskets will stop the leaking there.
There may be a water build up in the fuel system from old or bad gasoline and for that I would recommend adding some dry gas treatment.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Cave さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 163
