メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Power Button does not click after re-assembly
After putting the top on, the power button doesn’t click. It clicks fine until i clamp all the plastic clips around it in. Screwing it in or anything like that does not help either. Nothing seems to be in the way of the button either
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Just a thought. If switch uses mounting screws, maybe try putting some plastic washers between the heads and the computers frame to see if that makes a difference. My stance for my own personal equipment, if a solution works, it works and that is good enough for me. :-)
さんによる
コメントを追加
1 件の回答
Try reseating the ribbon cable that goes to the buttons. Most likely it's slightly out of position or something.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Thomas MacGregor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 131
