メインコンテンツにスキップ
The Acer Aspire E1 series is a line of notebook laptops manufactured and sold by Acer, Inc., an electronics corporation based in New Taipei City, Taiwan. The Acer Aspire E1 series was introduced in 2012.
Laptop plugged in not charging
Laptop plugged in not charging and will not charge at all
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Check too see if the laptop has a charging light, and if so make sure the light shows a charging indicator when plugged in. If it does not, then it could be a faulty charger or a short somewhere on the laptop motherboard. If you charger has a light on it showing its working fine and the laptop has a charge indicator showing that its not charging then it could be a short. If the charger or laptop do not have power indicators then go ahead and leave a comment for me too assist some more.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is displaying with x sign.
No Battery
Pl suggest to resolve the issue.
さんによる
コメントを追加
Is the battery original? A lot of PC laptops have problems with the batteries after 1-2 years where they just die. If the battery has never been replaced, start there and see if that fixes the issue - it almost always does on older laptops like this.
If that doesn’t work, try removing the Microsoft ACPI-Compliant Control Method Battery device, scan for hardware changes and it will reload once it is found again - DO NOT REMOVE THE DRIVER! You will find more then one with a dual battery compatible laptop, but the Acer likely doesn’t support this.
Dual battery compatible systems:
If you are still having issues, try replacing the charger. Acer does not use a sense IC like many other companies, so you can get a good quality aftermarket universal charger, like a Targus. Either get the OEM adapter or a good universal one made by Targus.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
t56ap さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 579
