メインコンテンツにスキップ
https://www.sony.co.in/electronics/support/televisions-projectors-lcd-tvs/klv-32r482b/specifications
2回答 すべてを表示
What can be the reason for getting these horizontal lines on my TV?
I purchased this TV 5 years back and has been all good till date. Suddenly it has started developing some horizontal image as shown/attached image
What may be the problem? How do i fix this problem? Would i need a technician help. How much can it cost?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
@h4harshith could be an issue originated from the T-Con board or bad LVDS cables/connectors. Unplug those and clean them. There is of course a possibility that this is a LCD controller board error from failed source drivers. That board is (permanently) connected to your panel. Check the thin ribbon cables coming from that board and entering the panel, by applying some pressure on those. See if that helps changing the picture. Of course, it is always nice to see what you see. Post some pictures of your boards etc. with your question
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
this method worked for me :
https://i.ytimg.com/an_webp/-79D61vg2mU/mqdefault_6s.webp?du=3000&sqp=CLut254G&rs=AOn4CLArUj1L2kj3Ku9p2FmnuLXw24YPzg
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Harshith Mulky さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 23
今までの合計 1,505
