My phone wont charge due to water damage. How do I fix it?
So i dropped my phone in the toilet like a dumb dumb and i immediately put it in a bag of rice and left it in there over night. I woke up the next morning and turned it on and everything still worked but then I realized the battery was running low so i plugged it in but it didn't work. Now my phone is dead and i have no way to charge it, i thought of removing the battery and putting it in a different phone and charge that way but it has a non-removable cover so i cant get to the battery. At this point i dont know what to do or if i actually can do anything.
2 件のコメント
My phone redmi note 6 pro was dead because of water. So what I do?
prop man さんによる
Oh might as well include this standard disclaimer quote from Reddit's /r/mobilerepair:
"Somebody said "Rice". If you're talking about a water damaged device, I hope you know putting it in rice is just a myth. Rice is unable to pull moisture from inside your device. While waiting for the rice to do it's magic trick you're letting that moisture form corrosion. This corrosion can and will cause short circuits. If you truely would like to save your device please take it to a reputable repair shop immediately and do not try to charge or power your device on. Applying power will cause the corrosion to happen quicker by elecrolysis. If you have a removable battery please take it out."
prop man さんによる
