メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ビデオ出力付きのPC用ディスプレイ(もしくはモニター)の修理ガイド
Samsung Monitor with black vertical line
Just wondering if anyone can help me with this. My Samsung C24FG73 has one black vertical line on it. I’m happy to take the monitor apart and fix it but I wouldn’t know what part to replace. Any advice would be appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
If you have eliminated your computer and video card as a source of the problem, probably would be a good idea to open up the monitor for a visual inspection of obvious malfunctioning components (for example, bulging capacitors, burn marks, etc. Probably would help others to identify the problem by posting a screen shot of the black line.
さんによる
Hey thanks, I just edited the original post with some pictures. I thought u had them up before but must have missed them.
Yeah I guess that your probably right will have to take a look when I get a sec to see if I can spot anything
さんによる
Wow, man. It looks terrible. Have you managed to solve that issue? Hope you have. I’d be grateful if you kept us updated on your problem. My friend used to have the same issue, but I can’t remember how he solved it. I guess he just bought Dell’s monitor instead. As far as I know, he has this monitor https://productz.com/en/dell-s2419hgf/p/.... Actually, I bought the same one. I think Dell makes the best monitors on the market, so I’d highly recommend you replace your monitor with Dell’s one. Still, tastes differ. So, I’ll be waiting for your reply.
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi @tralph ,
Sometimes this can be caused by a loose tab connection on the display panel itself. The connections are very fragile.
Sometimes it can be fixed by just pressing very gently down onto the tab so that it remakes the connection but you have to get to them first.
Here’s a link to a video (there are plenty of others) that may help.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi, i've got the Samsung Monitor as well (Samsung monitor S32D580T) with Vertical Lines popping up on the screen when connecting it to a Laptop, Please help if this can be fixed
さんによる
コメントを追加
I had a black stripe down the left hand side and it seems Windows adjusted my display settings without me touching them so that the settings on my laptop matched my monitor. Went in and changed it to “Show on two displays only” I turned my monitor off and then back on again and it was resolved
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
can you show me how to do it exactly?
さんによる
we tried updating the graphics driver but that did not work. says its up to date. no other option to change settings and the line just got worse. we're using a laptop by the way. i don't believe that should matter, right?
さんによる
コメントを追加
Just check for the flex cable inside the back of your monitor. You will have to open the back panel and have a look right there. probably a loose connection, or defective cable is your issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Similar issue, left hand side. Dotted line. Updated my graphics driver and it seemed to go away during that process
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tom さん、ありがとうございました!
統計データ:
過去 24時間: 16
過去 7 日: 118
過去 30 日: 655
今までの合計 43,197
