メインコンテンツにスキップ
2006年11月に北米で発売されたWiiは、任天堂初のインターネット接続に直接対応した家庭用ゲーム機で、オンラインゲームと、Wiiショップチャンネルを通じたゲームやメディアアプリケーションのデジタル配信の両方をサポートしている。
286回答 すべてを表示
How do I fix wii red blinking light
When I plug in my wii the power light blinks red. Every time I press the power button it has no effect on it. I have tried press and holding the power, reset, sync, almost every button on the wii. The only thing that I haven’t done is actually tear apart the wii and find out what might of went wrong. So is there anything I can do before I try ripping it open? I have had this wii for like 5 years so I think it might just be old but it’s still worth a shot seeing if anyone on here could help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
try unplugging it and plugging it back in
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I figured out what was cause of the problem. When you pop open the plastic cover where the power button, reset and disc trey is located you will see a chip next to the reset button its called a Bluetooth module chip you can search also on youtube how.. All you need to do is just pop it a lil bit and try to insert it again.. I idid it accidentally and it works. Im actually !#^&@@ that i bought a new power supply when my old one i still working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I bought a new Bluetooth module and replaced the old and it still doesn't work. One day, after it was unplugged for a few months, I plugged it in and it was working! Months later during a storm, power was knocked out, and the blinking red light is back.
Anyone have a sure fix?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Oops! 😬
You might've had a power surge. Unfortunately, this is hard to repair and requires microsoldering. Unless there is stuff you need it's mostly cheaper to buy a new (used) wii
さんによる
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 33
過去 30 日: 142
今までの合計 5,484
