メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
カラーサンライズシミュレーション、5種類の自然音、ラジオ機能付きPhilips Wake-Up Light目覚まし時計。2017年4月発売。モデル番号:HF3520/60。
Snooze is not working
Does anyone knows which part is for the snooze? My snooze is no more working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Underneath the white disk there is a microphone (a black round cylinder with a hole in it) that is activated when the alarm goes off.
画像
The white disk transmits the noise (caused by the tapping on the housing) to the microphone which snoozes the alarm.
So it could be that either the microphone is defective or that is simply blocked by a speck of dust.
I just blew into into it and it worked again.
I do not know how easy it is to replace the microphone, as I have not yet take the lamp apart (it still has warranty)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes i also found this part and thought about this but i was not really sure about it but i think i will order an Replacment microphone and will play arround with it :)
さんによる
Have you also tried how much the plastic parts need to be vibrating at yours?
さんによる
コメントを追加
Hi I think I found out the problem. There is a Piezo vibration sensor and it's oxidized. Have you seen at which position the sensor is at yours? I think there could be some with the sensor on the right side.
Info the sensor is 20mm diameter.
画像
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@timkrzyzanowski did you manage to change your Piezo sensor oxydated ?
I have the HF3520 and my issue come from this sensor as well. Did you find any spare parts ?
さんによる
Hi yes somehow a resolder worked now for 3 years but somehow it was very sensitive. Last month the error occurred another time an this time in soldered an new Piezo 20mm element to the cables. But be carefull to solder with the lowest possible temperature. If you're in Germany I could send you one of those if not you can order them easily at aliexpress or ebay.
さんによる
コメントを追加
回答を追加する
timkrzyzanowski さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 33
今までの合計 2,612
